I am using CY8CKIT-044 for development purpose .
When i tested the lin slave example by putting a break point at frame id read state , it was hitting every time when i send the frame at 19200 , 14400,10400 baud rates .
However when i reduced to 9600 baud rate it stopped hitting break point .According auto baud generation it should work for all baud rates but this is not happening .
The only change i have done in example project is setting baud rate to 19200 before it was 9600 when opened first time .
Hi Alok,
We would need following information:
1. Are you using CY8CKIT-26 with above kit?
2. What are the clock settings you have in your cydwr?
3. Can you fix the baud rate at 9600 and probe the Tx Rx lines?
Could you please update us on above ?
Please feel free to update for any clarification.
Harshada
I am not using CY8CKIT-26 , i am using TJA1020 as transciever .
My clock setting are default as come with example project .
In 9600 baud rate it works only when i send data at 9600 baud rate .
Below is snapshot of clock setting .
I am using this example project .
P4_SCB_LIN_Slave_Example.
