Hello all!
I'm using the Pioneer Kit and trying to receive and process the press of a button from a keyfob (iTag.)
I have a couple of issues:
1) How do I connect the PSoC to the iTag. I know from CySmart that it's address is FF:FF:00:00:F3:08
(I have a second one that is address ending in 9D:0F)
2) The device sends the Battery Level with a handle of 30 (UUID: 2A19) wth a value of 64 which I assume shows to a full battery. Is there a way to turn that off without reprogramming the iTag?
3) When the button on the tag is pressed, it sends Handle 35 (UUID: FFE1) with a value of 01. This is the one I want to use to toggle an output.
My intention is to use the iFobs to turn on and off alarms. Any assistance is greatly appreciated.
The iFob is using a Beken BK3431 that I can't find any data on, so I think everything needs to be done on the PSoC side.
Dan
BLE
Hi Dan,
Do you want to directly establish a connection with the iTag based on its address? To connect to the peer device, you can use CyBle_GapcConnectDevice after the target device is discovered by CyBle_GapcStartScan() and further scanning has stopped.
Can you clarify your second question? What would you like to turn off?
