Hie, I am using CY8CKIT-042. I have tried to interface this sensor using ADC but this does not give me proper output. Will you please anyone help me. I am reading ADC value and converting this value into millivolts . I am using this formula to conert voltage to temperature.
Temp = mVolts*500/12;
And one more thing if I remove Analog pin connection though I get same output as before. And if I use digital pin as a input then output is changing but still it is not true temperature.
Try this program. I don't have this sensor so I can't try it out.
Can you please post your complete project or a shortened version that shows the error so that we all can have a look at all of your settings. To do so, use
Bob
I made some changes in your project. See comments. Different from your post Temp = mVolts*500/12; the formula in main.c is different. I also updated your components to latest version.
Give this a try.
Bob
Thank you so much for your help but i think you missed to upload project .zip file. Will you do it again?
Thank you, I will try today.
