Is the miniprog4 programmer burnt out?
lvjingax
First like given First reply posted First question asked
Miniprog4 encountered an error while upgrading firmware, causing the device's indicator light to not light up when connecting TypeC to TypeA cable
Giraffe1492
25 sign-ins 25 likes received 10 solutions authored
It seems like the firmware upgrade process was interrupted, which might have caused the device to not be recognized by the Device Manager. To resolve this issue, you can try the following steps:
  1. Disconnect the MiniProg4 from your computer.
  2. Press and hold the Reset button on the MiniProg4.
  3. While holding the Reset button, reconnect the MiniProg4 to your computer using the TypeC to TypeA cable.
  4. Release the Reset button after a few seconds.
  5. Check if the device is now recognized in the Device Manager.
  6. If the device is recognized, you can try upgrading the firmware again using the PSoC Programmer software. Make sure to follow the firmware upgrade instructions carefully to avoid any issues.
If the device is still not recognized or the firmware upgrade fails again, it's possible that the MiniProg4 may have been damaged during the previous firmware upgrade attempt. In this case, you might need to contact Infineon for further assistance.
For more information on PSoC 4 MCU and related products, you can visit the following pages:
I hope this helps! If you have any further questions, please feel free to ask.
https://www.infineon.com/cms/en/product/universal-serial-bus/usb-c-charging-port-controllers/ez-pd-b...
https://www.infineon.com/cms/en/product/universal-serial-bus/usb-c-high-voltage-microcontrollers/ez-...
Aashita_R
50 likes received 100 solutions authored 250 replies posted
Hi @lvjingax ,
Before jumping to any conclusion, can you please share an image of the instructions or commands that come up once it stops upgrading firmware?
Aashita
The photos with errors at that time were not reserved, and the devices could not be enumerated in the Device Manager later. So now I don't know how to make the devices available, and I don't know whether the community can provide some help
Giraffe1492
Thank you for your help. Based on the advice you provided, Miniprog4 is now working properly
