songzaiwu:
your clock is too slow.
Set the clock to 12.0 MHz in the general tab. Set acquisition time to 2 clock cycles (setting lower doesn't work).
That yields 1.33 usec per channel conversion time.
---- Dennis Seguine, PSoC Applications Engineer
songzaiwu:
Hi @songzaiwu,
Adding to @DennisS_46's response, the maximum allowable clock frequency depends on the Vref voltage selection.
Taking PSoC 4100/4200 device Vref voltage selection as an example, the maximum allowable frequency will be as follows:
The displayed Acquisition time in your attached image is equal to (Nclk - 0.5)*(1/Fclk), where Nclk is the number of acquisition ADC clocks, and Fclk is the clock frequency.
Total acquisition and conversion time (sar_clk) = acquisition time + resolution (bit) + 2
As the Fclk is higher the time taken will be lesser.
Please, let us know if you need further clarification.
Thank you
Best Regards
Raj Chaudhari
