PSoC™ 4 Forum Discussions
TeMa_2997106
Level 6
Level 6
10 likes received 10 solutions authored 250 replies posted
Is there a way to monitor (dump) the value of the internal RAM?
I want to dump a running program without breaking it, instead of referencing the variable in the debugger.
Tetsuo
Len_CONSULTRON
Level 9
Level 9
500 solutions authored 1000 replies posted 750 replies posted
Tetsuo,
You can send your RAM value(s) out the UART port.  This is a common method.
Len
TeMa_2997106
Level 6
Level 6
Len-san,
Thank you for your support quickly.
Is it possible to monitor with a debugging tool such as ICE?
Currently, I am using the following tools.
(Sorry, this is a Japanese site)
http://desktoplab.co.jp/service.html
Called RAM Monitor, the tool can dump regardless of FW.
Tetsuo
Tetsuo-san,
The Cypress MiniProg3 has JTAG capability.  This should allow you to display the contents of RAM without stopping the debug session.
Len
TeMa_2997106
Level 6
Level 6
Len-san,
Is the JTAG port independent of the UART?
If yes, I think the JTAG command cannot monitor data from the UART, is it correct?
Tetsuo
Please refer to the MiniProg3 user guide for more information on different interfaces supported.
https://www.infineon.com/dgdl/Infineon-CY8CKIT-002_MiniProg3_Kit_Guide-UserManual-v01_00-EN.pdf?file...
P Yugandhar.
