I am trying to use the IDAC component in the PSoC 4 BLE. When I let the PSoC Creator auto-assign the pins during build, it assign the pin P2.7 [44] to the iOut which is unavailable on the board. I have assigned it to a analog pin (p0.0) but it doesn't work correctly and displays the following message:
"Function CSIDAC8.iout is reachable through the analog routing fabric, but using this pin may lead to routing congestion or failure."
I don't know if the problem is because of the pin I assigned or another thing I've done in the project?
Thank you
PSoC 4 MCU
Hi Jaleh,
Which version of PSoC Creator are you using at your side ? I tried opening the project with PSoC Creator 4.4. The project built fine for me and pin 2[7] was not used at my end. See the pin mapping below.
Vasanth
Hi Jaleh,
Vasanth
Jaleh,
The project you supplied built assigning the IDACout to pin P0.0 with no reported issues as you mentioned.
