IDAC PSOC4
Hi, I am using the IDAC of a PSOC 4. What is the temperature drift of the current? Is it the same tolerance as the reference voltage?
Vasanth
Hello Robin,
The drift value spec of the component is  10% (conditions -45 to 130C and 1.7V to 5.5V and across all corners). This is the worst case value and the actual device performance might be much better.
VSRS
Vasanth
Temperature drift of the IDAC is not normally spec present in the datasheet. Could you please let us know what you are trying to do?
VSRS
Simplified, I am using the IDAC in combination with a resistor and an Opamp (Buffer) to generate a voltage over another variable resistor. Simultanouesly, I am measuring the current through the variable resistor to calculate the power dissipation.
I want to keep the electrical power constant for futher regulation processes. To calculate the tolerances of this regulation, I need to know all drift parameters.
Robin
Vasanth
Hello Robin,
VSRS
