YoIs_1298666
250 sign-ins 100 replies posted 100 sign-ins
I am considering error handling for I2C slave of PSoC4000S.
Please see the return value of SCB_I2CSlaveStatus() API.
[In case of write operation (master -> slave)]
1. Just program the error handling between /* your error handling here */ and /* your error handling end */.
        if(0u != (I2CS_I2CSlaveStatus() & I2CS_I2C_SSTAT_WR_CMPLT))
            if(0u != (I2CS_I2CSlaveStatus() & I2CS_I2C_SSTAT_WR_OVFL))
            else if(0u != (I2CS_I2CSlaveStatus() & I2CS_I2C_SSTAT_WR_ERR))
            /* your write operation handling here */
            /* your write operation handling end*/
2. Just progarm the timeout handling between /* your timeout handling here */ and /* your timeout handling end */.
    for example:
        while(0 != (I2CS_I2CSlaveStatus() & I2CS_I2C_SSTAT_WR_BUSY))
[In case of read operation (master <- slave)]
3. Just program the error handling between /* your error handling here */ and /* your error handling end */.
        if (0u != (I2CS_I2CSlaveStatus() & I2CS_I2C_SSTAT_RD_CMPLT))
            if(0u != (I2CS_I2CSlaveStatus() & I2CS_I2C_SSTAT_RD_OVFL))
            else if(0u != (I2CS_I2CSlaveStatus() & I2CS_I2C_SSTAT_RD_ERR))
            /* read operation handling here*/
            /* read operation handling end*/
4. Just progarm the timeout handling between /* your timeout handling here */ and /* your timeout handling end */.
    for example:
      while(0 != (I2CS_I2CSlaveStatus() & I2CS_I2C_SSTAT_RD_BUSY))
Is there anything else I can prepare?
Yocchi
AikoO_51
100 sign-ins First question asked 50 solutions authored
This is exactly one of methods to check passing data for I2C slave.
You can use these Slave Status Contents.
Also it might be necessary to prepare own status for your project to check whether closed passing data correctly. (such as “length of packet”, “the start and end of packet” and so on)
For reference, here’s a part of example from sample code(CE224599) in PSoC Creator below.
Aiko Ohtaka
Infineon Technologies
AikoO_51
Aiko Ohtaka
Your point is to check the data error when there is no hardware error and the data communication is successful.
My question is about error handling when an error is detected in hardware.
Is this enough for hardware error handling?
Yocchi
Yes, SCB_I2CSlaveStatus() is good for checking hardware error.
Also your suggestion would work well.
A source code for firmware operation error will be mostly after checking hardware error with this API in any I2C code example.
So you can make sure of this API in same code example I suggested as well.
Aiko Ohtaka
I have prepared a sample project for handling I2C slave errors.
I2C slave error handling for CY8CKIT-145-40XX
The I2CS_I2C_SSTAT_WR_ERR and I2CS_I2C_SSTAT_RD_ERR are as follows.
Yocchi
