PSoC™ 4 Forum Discussions
bytedance
First like given First reply posted First question asked
I2C simulation of CY8C4014LQI-422 chip The requested packet is not found.
BiBi_1928986
Level 7
Level 7
500 replies posted 250 replies posted 250 sign-ins
Hello.
Did you put pull-up resistors on clock and data pins?
ncbs
500 replies posted 50 likes received 250 sign-ins
Hi @bytedance,
I would suggest you to go through the I2C code example present for PSoC 4000 device: CE222306 - PSoC 4 I2C Communication with Serial Communication Block [zip file] [CE document ].
As @BiBi_1928986 mentioned, ensure that you have the hardware components, both the series and the pull-up resistors, connected to the I2C lines. If you are using a terminal/bridge control panel to view your I2C messages, make sure you have the right settings for communication speed and addressing mode.
Nikhil
bytedance
okok! thank you.
