I2C control of the CYBLE-012011-00
Can I use an external microcontroller to connect CYBLE-012011-00 over I2C?  What digital communications can be used to have an external MCU master and the CYBLE-012011-00 as the slave?  Thanks very much!
Bob_Marlowe
Level 10
Level 10
Welcome in the forum, Benjamin.
Your selected CYBLE-012011 chip has got two serial interface blocks from which you can use one as I2C slave or master.
Best for you will be to download and install PSoC Creator. You will need a programmer to flash your code, so get hands on a Miniprog3.
Bob
Bob_Marlowe
Level 10
Level 10
Bob
