PSoC™ 4 Forum Discussions
TamirM
25 sign-ins First like given 10 questions asked
Im experiencing clock latching from I2C slave.
I want to toggle the I2C clock (SCL) a few times to make the slave to release the line.
I couldn't find an API to do so.
How can I do that?
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
I think that the part which back up the pin configuration and restore it is in the loop
        uint32 regVal, regValtemp;
        regVal = CY_GET_REG32(I2CM_scl__0__HSIOM);
        regVal = CY_SET_REG32(I2CM_scl__0__HSIOM, regVal);
So the author of the discussion was
if sda == 0 enter the loop (while)
back up the register setting of SCL
configuring the SCL pin as GPIO
flip SCL once
restore the SCL configuration
After the program exited the loop, it cleans the status of I2C component by calling
    status = I2CM_I2CMasterSendStop(timeout);
    //Reset I2C
    I2CM_I2CMasterClearStatus();
    I2CM_I2CMasterClearReadBuf();
    I2CM_I2CMasterClearWriteBuf();
Could I make sense?
moto
MotooTanaka
Level 9
Level 9
Yes, it helps.
I just need few clarifications:
Calling the following functions is enough to reset SCL pin the its default I2C configuration
(in case of "Show I2C terminals" box is UNCHECKED)?:
- I2C_I2CMasterClearStatus();
- I2C_I2CMasterClearReadBuf();
- I2C_I2CMasterClearWriteBuf();
MotooTanaka
Level 9
Level 9
flip SCL once
    //Reset I2C
Could I make sense?
moto
TamirM
You couldn't make more sense 🙂
Thanks a lot. toggling the clock actually helped and recovered the I2C
