Here is the original thread that addresses this issue. I2c Issues
The issue is marked as answered, but there is no answer to the original question:
Are there known issues using P5.0 and P5.1 as allowed by PSOC creator on this module? I am not getting an ACK if these pins are used.
If I assign the pins to P3.4 and P3.5 (allowed for SCB1 sda and scl), I get proper ACK and function.
If someone could help, I would greatly appreciate it. I already have a board layout done using P5.0 and P5.1.
We tested your project with pin set to P5.0 and P5.1 and checked the output on an oscilloscope. Both the pins are working correctly as a digital output pin.
-Sayani.
This is not a known issue with CYBLE-022001-00.
Can you reproduce this issue on CYBLE-022001-EVAL EZ-BLE™ PRoC™ Evaluation Board?
If yes, using a 'scope do you observe SCL being held low?
Please upload any relevant 'scope traces, hardware schematic PDF and PSoC Creator project for written for CYBLE-022001-EVAL board for everyone to have a look at it.
Troy,
Thanks for your reply. Here are answers to your questions:
I am using the CYBLE-022001-EVAL board for development.
SCL is not being held low when using P5[1] for SCL signal. See picture
attached:
With no ACK being received, the I2C master issues a STOP and retry.
When SCL is assigned to P3[5] and SDA is assigned to P3[4], SCL clock
stretching and ACK occur:
I am attaching archive of two projects. One that uses I2C Slave and one
that uses EZI2C SCB configurations. Both function the same.
Scott Coleman
949-289-1578 cell
scott642@cox.net
On Wed, Oct 24, 2018 at 2:01 PM Troy Gentry <community-manager@cypress.com>
-Sayani.
