Hello, I am new to PSOC, and is currently working in CY8C4245AXI-483
I am trying to make a simple project to read and write the data in external eeprom using i2c, untill now i have aquired the result but the data i stored is in "HEX" whereas the data i received on my serial is in ascii
EX: I am sending (0x42, 0x43, 0x44, 0x45, 0x46, 0x47, 0x48, 0x49)
and receiving "B C D E F G H I
Why do i not get HEX in output and how to get it ???
My code is given below
#include <project.h>
void main()
uint16 read_val[8]; //Array to read data from EEprom
uint8 array[8] = {0x42, 0x43, 0x44, 0x45, 0x46, 0x47, 0x48, 0x49}; //Array to write data to EEPROM
uint8 i;
uint32 status; //variable to read error/status of I2C
I2C_Start();
UART_Start();
for(;;)
status = I2C_I2CMasterSendStart(0x50, I2C_I2C_WRITE_XFER_MODE); //Send start with slaveID 80u & write/read transfer mode
if(I2C_I2C_MSTR_NO_ERROR == status) //Check status
status = I2C_I2CMasterWriteByte(0x00); //address of eeprom on which data needs to be written
{ //if valid write data to external eeprom
for(i=0; i<8; i++)
status = I2C_I2CMasterWriteByte(array[i]);
if(I2C_I2C_MSTR_NO_ERROR != status) //Check status
{ //if success come out of loop
break;
else
UART_PutString("error"); //else print error
I2C_I2CMasterSendStop(); //Send stop
/***************Read that same data from external EEPROM**************************/
CyDelay(500u);
status = I2C_I2CMasterSendStart(80u, I2C_I2C_WRITE_XFER_MODE); //Again send start
status = I2C_I2CMasterWriteByte(0x00); //address of eeprom to read data on it
CyDelay(50u);
status = I2C_I2CMasterSendRestart(80u, I2C_I2C_READ_XFER_MODE); //Send restart
if(I2C_I2C_MSTR_NO_ERROR == status) //Check status if no error
for(i=0; i<8; i++)
if(i<7u)
read_val[i] = I2C_I2CMasterReadByte(I2C_I2C_ACK_DATA); //receive data bytes with ack
else
read_val[i] = I2C_I2CMasterReadByte(I2C_I2C_NAK_DATA); //receive last byte with nack
for(i=0; i<8; i++)
UART_PutChar(read_val[i],); //display data on uart
UART_PutString(" ");
CyDelay(500u);
CyDelay(3000u);
/* [] END OF FILE */
Hello.
You need to convert the HEX into ASCII-HEX before sending to UART.
I've written a routine to do this. I'm sure there are lots of different ways to do this.
unsigned char hex_to_ascii[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x41,0x42,0x43,0x44,0x45,0x46};
unsigned char temp1;
* Function Name: prthex()
* Summary:
* Print a hex byte as ASCII, followed by a space.
* Parameters:
* unsigned char
* Return:
* None.
void prthex(uint8 hex)
{temp1=(hex&0xf0)>>4;
temp1=hex_to_ascii[temp1];
UART_1_PutChar(temp1);
temp1=(hex&0x0f);
UART_1_PutChar(0x20);}
Hello.
* Summary:
* Parameters:
* unsigned char
* Return:
* None.
temp1=(hex&0x0f);
