urchc_1533771
I can`t control  output pin. I made as in example :
#define LED_OFF                            1u
#define LED_ON                            0u
RED_Write(LED_ON);
RED_Write(LED_OFF);
But it always On and not changed 😞
Attached pin settings window.
What wrong ?
Bob_Marlowe
Level 10
Level 10
Your main-loop is
    for(;;)
        /* Place your application code here. */
        LED_Write(LED_ON);
        CyDelay( 500);
        LED_Write(LED_OFF);
So you will need another delay after switching the LED off or it will be switched on immediately when the loop is executed again.
Bob
rola_264706
Level 8
Level 8
        Chaplin: please send your code so we can determine what the issue is.
urchc_1533771
attached
Bob_Marlowe
Level 10
Level 10
Your main-loop is
    for(;;)
        LED_Write(LED_ON);
        CyDelay( 500);
        LED_Write(LED_OFF);
Bob
rola_264706
Level 8
Level 8
Chaplin: Here is your program working as it should.
rola_264706
Level 8
Level 8
Here is the Cypress app on using pins.
urchc_1533771
