xime_4617841
Now I need to use modbus in psoc4, so I need to know how to use the serial port interrupt.It seems that I need to use the function CY_ISR(isr_1_Interrupt), but I'm not sure how to use other functions such as read Tx/Rx status/data and send data in this function.Another problem is the configuration about the UART unit. So could anyone talk about it? Or maybe a code example、helpful blog and other things about it. Thanks a lot
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Following is my sample
tty_utils a utility sample for CLI type program
I wonder if this can be a sample to begin with
moto
MotooTanaka
Level 9
Level 9
moto
BragadeeshV
Hi xime_4617841​,
In addition to MoTa_728816​-san's example program, you can use the following reference links to get started with PSoC 4 SCB interrupts:
1. PSoC 4 Interrupts - https://www.cypress.com/documentation/application-notes/an90799-psoc-4-interrupts
2. PSoC 4 SCB Component Datasheet - https://www.cypress.com/documentation/component-datasheets/psoc-4-serial-communication-block-scb
3. Code examples - CE224406 - PSoC 4 UART - https://www.cypress.com/documentation/code-examples/ce224406-psoc-4-uart
4. PSoC 4 Architecture TRM
5. PSoC 4 Register TRM
Bragadeesh
Bragadeesh
