Hello.
I want to communicate to other device by using PSoC I2C component but I dont know how to use.
I want to put PSoC as master and the device as slave and just want to write.
Could anyone give me some easy sample code to use I2C??
Byte I2C interface is quite simple: After setting up the component and starting it you use
I2C_MasterSendStart(DeviceAddress,I2C_WRITE_XFER_MODE); // Initialize a transaction for writing
I2C_MasterWriteByte(Register); // Indicate which register you want to write to
I2C_MasterWriteByte(Value); // Write to register
I2C_MasterSendStop(); // End of transaction
When you want to read from a device you use (example for reading two bytes
I2C_MasterWrite(Register); // Indicate which register you want to write to
I2C_MasterSendRestart(DeviceAddress,I2C_READ_XFER_MODE);
I2C_MasterReadByte(I2C_ACK_DATA); // Read from register
I2C_MasterReadByte(I2C_NAK_DATA); // Read from register, last byte is NAKed
Not too difficult. Keep in mind that most of the APIs (except those for reading a byte) return a status byte which, when non-zero indicate an error condition.
The high-level APIs must be used in this way:
Writing to slave Count bytes
I2C_MasterWriteBuf(SlaveAddress,DataPtr,Count,I2C_MODE_COMPLETE_XFER);
Reading from Slave sending register/command byte first:
I2C_MasterWriteBuf(SlaveAddress,&RegAddress,1,I2C_MODE_NO_STOP);
I2C_MasterReadBuf(SlaveAddress,DataPtr,Count,I2C_MODE_REPEAT_START);
*** Important: I2C needs two pull-up resistors (~ 2.2K) on SDA and SCL. The pins should be configured as "Open drain, drives low" and the initial drive level = High.
Bob
Bob
Sorry, I have a question.
When I put
and build it, error comes up and that says they are undefined reference.
Is there any other thing I should do??
Can you please post your complete project or a shortened version that shows the error so that we all can have a look at all of your settings. To do so, use
Bob
Thank you so much!!!
I will try it!!
Sorry I dont know how to attach it...
I attach the image instead.
For your device the API names are formed as I2C_1_I2CMasterSendStart(). Look into the component's datasheet (right click)
To attach a file here, click on "advanced Editor"
Bob
