Purchased Kit: CY8CKIT-005 MiniProg4 Program and Debug Kit
Installed file: PSoCProgrammerSetup_3.29.1_b4659_0.exe
IC Type of product:CY8C4245LQI-483
Interface: SWD Programming
Hex File: Cypress_sample_V99_V154.hex
Third part tool: NI Teststand
Would you please tell me how to use command line interface for automatically programming. I have no idea about it. It would be highly appreciate if someone can give me a CLI sample for study or trial run.
HI @Michael_777 ,
Thank you for using our products and yes we do have sample scripts that you can use to automate the programming operation on PSoC 4 devices.
Please take a look at the KBA Programming PSoC™ 3, PSoC™ 4, and PSoC™ 5LP MCUs using PPCLI – KBA232937 which gives the detailed commands that you can use in your custom script to automate the PSoC 4 programming using our PPCLI tool installed along with PSoC Programmer.
The KBA mentioned above also provides a sample example script to help you get started.
Hope this helps
Alen
