10:31 PM
Nov 29, 2016
10:31 PM
I use psoc4 the bootloader and bootloable components, to upgrade a device when it is successful, but to upgrade a number of equipment, then it is not possible.I use the communication is 485 communications.
06:03 AM
Dec 07, 2016
06:03 AM
It is not possible to upgrade 10 devices simultaneously. Even if you are sharing the UART channel between devices to do it one by one, then address detection may be required which is not implemented on the host side. So it won't be possible unless you write your own code for all these.
VSRS
