Hi Support Team,
I build a project in Modus ToolBox2.2 about SAR ADC. I will enable hardware averaging :
1 The following three configuration options are not covered in the initialization code, and using code as an example, can you explain the meaning of each in detail.
"Sequential,Sum"
"Sequential,Fix"
"Interleaved,Sum"
2 What are the APIs involved in this feature?
Thanks!
PSoC 4 MCU
Hi ,
This configuration sets how the hardware averaging mode operates. If Sequential, Sum is selected, each ADC conversion result is added to a running sum. It’s then shifted at the end of the scan so that it fits into a 16-bit result word. If the Sequential, Fixed mode is selected, accumulated result is shifted back into a 12-bit result. In either sequential mode, the scan pauses on the channel being averaged and all the samples for the average are taken before moving onto the next channel in the scan. This can reduce the maximum available scan rate substantially when any channel in the scan is averaged in this way.
For this reason, the Interleaved, Sum mode is also available. In Interleaved mode, only one conversion is taken on each channel before moving on, but channels that have averaging enabled get the preset number of samples accumulated in their result register. In Interleaved, Sum mode the overall scan rate is not reduced. This means that channels not requiring averaging can still be sampled at the original scan rate. An end of scan interrupt is still
produced at the end of every scan; channels that utilize interleaved averaging are not marked as ‘valid’ until the correct number of scans have been taken.
Vasanth
Hi ,
Vasanth
Hi Vasanth,
SAR config para as below:
Cy_SAR_Init(SAR_HW, &SAR_config);
Cy_SAR_Enable(SAR_HW);
Cy_SAR_StartConvert(SAR_HW, CY_SAR_START_CONVERT_CONTINUOUS);
1. VRef = VDDA/2
2 . Vneg is Vref
3 .single-end
4. 12bit
Vplus vol is 4.5 V
The input voltage range is 0-- 2VREF, but which is actually 2.5V?
Hi ,
I am not sure what exactly is the question? Could you please elaborate the actual question. I will try to answer from what I understood. In case if you have used
1. VRef = VDDA/2
2 . Vneg is Vref
3 .single-end
4. 12bit
Your range should be 0-2VREF as you have expected. Or 0-VDDA in your case. So if the VDDA is less than 5, the ADC range will be also affected. In case I have understood the question wrongly, kindly let me know.
Vasanth
