yiar_4652736
First like given
I'm using CapSense Tuner to see 16 sensors on the graph view. However, I can't see the exact value of the sensor signal in the graph. It shows a value around 50,000 (16 sensors all connected with cables cause a lot of interference). Is there a way to scale the graph?
Hari
Hi yiar_4652736
To zoom into the graph, you can simply click and drag to enlarge the waveform like you would on an standard tool. You can place the cursor where the signal is starting and click and drag towards the right to zoom. dragging to the left will zoom out to restore the entire waveform.
Please let us know if this helps.
Hari
Hari
Hi yiar_4652736
Hari
