Could you please show me how to program CY8CKIT-049-42XX Kit with Miniprog3 programmer using SWD mode?
Chandresh
Hey I got it working now.
I was turning the Power on and off by putting the Miniprog3 in External power mode and then again on 3.3V.
There is no external power to me putting the miniprog3 will turn the device's power off as miniprog3 is no longer powering the device thinking it has the external power.
Anyways,
Thank you Bob.
Snap off the programmer part of your -049 kit. You can solder 5 posts (clearly marked on silk screen) and attach the miniprog to the pcb.
Bob
I tried that,
I also tried detecting the chip from miniprog3 when the switch on the -042 kit is pressed and when it is not pressed while i am turning on the power to the chip.
It doesnot detect under the miniprog3 connections umbrella as you can see in the attachment in the psoc creator.
Chandresh
"turning on the power to the chip" How you do that? The programming part is snapped-off including the switch and the board will be powered through the miniprog3.
Bob
PS: Send a picture of your connection PC, board,miniprog
Anyways,
Thank you Bob.
