KeLi_1455086
First like received First like given Welcome!
I'm trying to build a robot arm with servo motor (SG90) and controlling capsense slider and touch button. Im use  CY8CKIT-145 kit to build this project. but I found the servo is not running stable. looking like the capsense scanning will stop the PWM. anyone can help!
我改了一下代码,你试试是否可以正常工作。
LinglingG_46
1000 replies posted 10 questions asked 5 questions asked
The CapSense have no ability to prevent the PWM.
Could you give me a simple project to reproduce the issue?
project file attached!
Thanks!
从工程看,CapSense 与 PWM 之间不存在相互干扰的情况。问题应该出在你尝试在 PWM 运行过程中直接修改其比较寄存器,这样做很容易导致 PWM 输出 glitch 等于预期不符的波形。建议你使能四个 PWM 的 compare swap 功能,并通过 PWM_1_TriggerCommand() 来触发 switch 动作,这样新的比较值就不会在当前周期中直接覆盖现有比较值,而是在 PWM 接下来一次的 TC 事件发生时将新的比较值拷贝的现有比较寄存器并生效。
我已修改,但仍然不能正常運作. 請看看!
Thanks for your help, now I know how it work!
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Beta tester First comment on KBA 1000 replies posted
I briefly read your project and the configuration of PWM might be wrong.
I have posted a sample using SG-90. (I'm sorry it's in Japanese)
TSoC CY8C4146LQI-S433 基板 サーボ SG-90 サンプル
But please take a look at the PWM setting in the project attached.
moto
Thanks for your help, now is working.
