Michael_777
First reply posted First like given First question asked
How to handle the xxx.cyacd programing based on previous hex file environment.
Kit: CY8CKIT-005 MiniProg4 Program and Debug Kit
Installed file: PSoCProgrammerSetup_3.29.1_b4659_0.exe
Auto programing EXE: ppcli.exe
Manual programing EXE: PSoCProgrammer.exe
IC Type:CY8C4245LQI-483
Connector: SWD Programming
FW Hex File:  Cypress_xxxxxx.hex
But there's a ECN now that the FW format has been changed from HEX to CYACD. So would you please give me some advice how to handle that, such as the kit, exe file, and so on, thanks.
Alakananda_BG
50 likes received 250 sign-ins 250 replies posted
Hi @Michael_777 ,
Can you refer to the below code example and let us know if that helps.
Alakananda
Alakananda_BG
Hi @Michael_777 ,
Can you let us know which ECN are you referring to and can you also send the link to the ECN.
Alakananda
Hi Alakananda,
For the ECN, its purpose is to inform us  that there's a change of the FW of the DUT during mass production in our factory. Unfortunately the format of the FW has been changed from HEX file to CYACD file. It seems the previous programming kit (CY8CKIT-005 MiniProg4)  we are using now is not matched. So, how can we do if we try to use  the new CYACD file for  this IC CY8C4245LQI-483. What kind of  programming kit is suitable? And how to use it like the CLI, thanks.
Best Regards
Alakananda_BG
Hi @Michael_777 ,
CYACD file is mainly used for bootloading purpose, you can refer  to the below document for more information on cyacd file.
https://www.infineon.com/dgdl/Infineon-Component_Bootloader_and_Bootloadable_V1.20-Software%20Module...
The programming tools like cypress programmer or PSoC programmer does not support CYACD files.
Alakananda
Hi Alakananda,
Appreciate your great support. I'm afraid I still have some doubts after reading the document you provided. Can you please recommend us the appropriate Kit Model and the SW as well to make it suitable for FCT fixture internal, thanks.
Alakananda_BG
Hi @Michael_777 ,
Alakananda
