D_Sd_3235936
Level 4
Level 4
25 sign-ins 50 questions asked 25 replies posted
I am working on a bootloader project.
Would like to get the start addresses for the below sections:
1. META DATA BTLDBL.
2. CheckSum Exclude
3. User Space.
4, BTLDBL
5. BTLDR
Can CySmart help me get this info?
Debug/Breakpoint is not an option.
Bootloader is built in the following manner:
Case # 1. Bootloadable application
     *  _______________________________
     * | Metadata (BTLDBL)             |
     * | Checksum Exclude (BTLDBL)     |
     * | BTLDBL                        |
     * | BTLDR                         |
     * |_______________________________|
RyanZhao
250 sign-ins First question asked 750 replies posted
You can get these info from .ld file and .cyacd file, combined with your project.
The datasheet of bootloader and bootloadable and PSoC4 programming spec may help undertand these sections better.
http://www.cypress.com/documentation/component-datasheets/bootloader-and-bootloadable
http://www.cypress.com/documentation/programming-specifications/cy8c4xxx-cyblxxxx-programming-specif...
