PSoC™ 4
How to generate the raw binary file from PSoC creator 4.2 on PSoC4100S and how to flash the generated raw binary into PSoC 4100S?
DheerajK_81
In PSoC Creator, go to Build Settings > ARM GCC Version > User Commands where you can specify the post build commands to generate the bin file. For the conversion itself you will need a third party hex to bin converter tool. The commands for conversion should then be added based on the syntax provided by the third party tool in the post build.
"C:\Program Files (x86)\Cypress\PSoC Creator\4.4\PSoC Creator\import\gnu\arm\5.4.1\bin\arm-none-eabi-objcopy" -S -O binary ".\CortexM0p\ARM_GCC_541\Debug\Design01.elf" ".\CortexM0p\ARM_GCC_541\Debug\Design01.bin"
DheerajK_81
