KaSa_1259906
First like received
I got this error while trying to compile a project. I am using CY8C4247AZI-M485
Error in component: cy_boot. The cy_boot_v4_20 component (cy_boot) is not compatible with the selected device. Please check the component datasheet for details on updating to a compatible component.
I was looking around the forum and I found that I have to update my components. I checked and found that my components are updated see attached. Any idea what else I could do?
Bob_Marlowe
Level 10
Level 10
Just "compiling" the project will not be enough, you have to "build" your project to re-generate the component's sources.
When still in trouble post your complete project so that we all can have a look at all of your settings. To do so, use
Bob
Thanks for your reply Bob, I actually build before compile. I started again from scratch ( new project) and I was able to rebuild just fine, Problem solved.
