gibe_285051
5 replies posted First like received First reply posted
Hi Everyone,
I have a small issue with this Soc - C8YC4147AXI-S475 , I tried to enable the WCO PLL to have an accurate SYSCLOCK for the CAN but I don't know how to enable it.
Below you can see the warning :
Here my clock design
In my hardware design , I  have a external crystal of 32.768 KHz between P0.5 and P0.4 .
I added this code in the main
CySysClkImoStart();
CyDelay(500);
CySysClkWcoStart();
CyDelay(500);
CySysClkImoEnableWcoLock();
Actually its impossible to receive or transmit CAN Message , I'm supposed this issue is the problem.
its really annoying because with this soc - CY8C4247AZI-M485 ,  you can trim the IMO directly in the system clock
Thank for your help .
Vasanth
WCO trimming is not available for the C8YC4147AXI-S475 4100S Plus device you are using. We understand the error message should have been different inside the component for this particular device. You have to use ECO with higher accuracy as the HFCLK source. This will resolve the issue at your end.
Vasanth
Vasanth
Vasanth
