I'd like to modify control parameters on-the-fly and confirm behavior of a motor.
Ex. motor target speed, PI gain of closed loop, OCP threshold.
It is used "Bridge Control Panel Monitor" to confirm behavior of a motor.
What tool or method can I use to modify control parameters on-the-fly while CPU running ?
Kazunari Hayashi
ispn:39608:1:0
l1:314:1:0
Hi @NXTY_hayashi,
We don't have any tool to modify the parameters while the CY8CKIT-037 Motor kit is running. You have to insert the section of code for serial communication which enables the modification of the parameter during the run-time.
Please, let us know if you need further clarification.
Thank you
Best Regards
Raj Chaudhari
Hi @NXTY_hayashi,
Thank you
Best Regards
Raj Chaudhari
Dear Raj-san,
I can understand the method and try it.
Best Regards
Kazunari Hayashi
