Hi, Community
I am using ModusToolbox 3.0 and Library Manager 2.0 .
I have created a custom BSP using the same method as the link below.
However, my project build failed.
Here is the reason :
make: *** Build support for the target device not found. Run "make getlibs" to ensure all required build and code dependencies are present.. Stop.
So, I ran the "make getlib" command and "make bsp TARGET_GEN=(My BSP)" from the terminal.But, both of them terminate with an error.
What should I implement to resolve the error?
And, I also checked this article.
I have confirmed that the project will include the following folders.
My WorkSpace \ mtb_shared
\-mtb-hal-cat2
\mtb-pdl-cat2
\ recipe-make-cat2
\ .settings
\ capsense
\ core-lib
\ core-make
Chihiro Tatebayashi
- Modus tool box 3.0
Hi @NXTY_Tatebayasi ,
I can see you have tried the CLI method(terminal). Can you please try to create a custom BSP by using the build targets option which is mentioned in the same KBA?
Please refer to the screenshot below:
Warm Regards,
Gautami J
Warm Regards,
Gautami J
Hi, @Gautami_12 san
Thank you for reply.
After updating the library, this problem was resolved!
Chihiro Tatebayashi
