I use an CY8CKIT-041-41XX and i want to connect an 128x64 oled display. I saw something online but they don’t work with my system. So How can i connect and program everything?
I just posted my sample at
For your board, please change the target device and pins to match your board.
moto
Hi @Pako887
Can you please share the online resource that you referred to? Were there any console error messages while trying the program the device while interfacing with the OLED display?
Also please refer to this code example which interfaces the SSD1306 128*64 OLED with PSoC 4.
Thanks and Regards,
Leo
hi thank for the answer. I try to use this github but when i try to build the project, the IDE say
Sorry I continue here. when I compile it it tells me that the component is no longer compatible with the selected device. Or it tells me that the project is corrupted and it can't find some files
Hi @Pako887
Did you change the device using the device selector after cloning the project and opening it? If so to which device did you change? Also, can you clarify which kit you are interfacing with the OLED? Is it the PSoC 4100S Pioneer Board?
Thanks and Regards,
Leo
Thanks a lot for the answer. I changed the device with the device selector. I'm using a CY8C4146AZI-S433 this
Hi @Pako887
Glad to hear that. Please let us know if you have any more queries.
Thanks and Regards,
Leo
I am misunderstood. The github doesn't work unfortunately with my board
Hi @Pako887
Can you please share the screenshot of the console error messages you observed while programming the board?
Thanks and Regards,
Leo
moto
I'm using PSoC Creator 4.4.
Would you try with v4.4 if possible?
moto
Hi @Pako887 ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Leo
