PSoC™ 4 Forum Discussions
Hi,in AN64846,Getting Started with CapSense,I'm confused about "support higher parasitic capacitances",I think that for small finger capacitance,it should support higher parasitic capacitances,which is in contrast with description in follow picture.
So,how to calculate parasitic capacitances according to finger capacitance?
Another related question:What's the meaning of CMOD and how to chose it?
Thank you
Best wishes
ShanmathiN_06
25 likes received 10 likes received First like received
If the parasitic capacitance (Cp) of your sensor is higher than 45 pF, then you would have to use manual tuning.
Typically, the capacitance added by finger (Cf) would be higher than 0.2 pF.
You design CapSense sensors in such a way that Cp is less and choose an overlay, such that the Cf would be high.
You can refer to PSoC 4 CapSense design
Cmod is required for the operation of CapSense to maintain AMUXBUS at a constant Vref.
Recommended value- 2.2 nF
You can refer to Section 2.3.2 of http://www.cypress.com/file/41076/download.
Shanmathi
ShanmathiN_06
Shanmathi
