TaMa_4718096
10 replies posted First like given 5 questions asked
I use Matrix buttons of CapSense in the following environment.
If Cy_CapSense_GetTouchInfo detects two touches, where are the first and second slot IDs stored?
  • Development tools : ModusToolbox 3.1
  • Device : PSoC 4100S Max
Arpit_S
100 solutions authored 250 sign-ins 10 likes given
Hi @TaMa_4718096 ,
This API call requires widgetID as one of the input arguments. A macro for the widget ID can be found in the cycfg_capsense.h file defined as CY_CAPSENSE_<WIDGET_NAME>_WDGT_ID.
For Slot IDs, you can refer to https://github.com/Infineon/cce-mtb-psoc4-msc-capsense-guard/blob/main/main.c
Cy_CapSense_ScanSlots(CY_CAPSENSE_GUARDSENSOR_FIRST_SLOT_ID, 1, &cy_capsense_context);
Here I have used Slot IDs
Thanks!
Kind Regards
Arpit Srivastav
Arpit_S
Hi @TaMa_4718096 ,
Thanks!
Kind Regards
Arpit Srivastav
