I am using CYBLE222014 with EZ-Serial firmware pre-programmed.
I'd like to change MTU size up to 512bytes.
How can I achieve it? And what is the default MTU size for EZ-serial firmware?
Thank you.
For 128K Modules , default MTU size is 384 byes ( and maximum size, a 128 K device with EZ serial can support) and for 256 K module default MTU size is 512 bytes ( Maximum MTU size) in Firmware V1.1.1.
There is no command to send a MTU exchange request. However, if you are using any other client device ( Like CySmart ) you can send a MTU exchange request with the MTU size you want because the EZ Serial has logic to negotiate the MTU size.
-Gyan
-Gyan
