I want to learn how to build and program a Custom Bootloadable Application for "KitProg3". I have CY8CKIT-149, I want to create bootload a custom project to the PSoC5-LP device.
I see a user guide for how to bootload a custom project for "Kitprog2". However, I do not find a guide for "KitProg3".
Reference - Section 9.1 of https://www.infineon.com/dgdl/Infineon-KitProg2_User_Guide-UserManual-v01_00-EN.pdf?fileId=8ac78c8c7...
Hello.
Just follow the instructions you found in Kitprog2 manual for building/bootloading a bootloadable project into Kitprog3's 5LP. It's also the same instructions as found in Kitprog1 (on KIT-059, KIT-042, etc...).
Just be aware that once you change the bootloadable in Kitprog1/2/3, you can no longer program/debug the KIT-149 target PSoC. In order to restore those functions, re-download the original Kitprog3 bootloadable. Instructions on how to do that are given in Kitprog3 document.
I don't know why Infineon decided to delete such useful information on developing a 5LP bootloadable from Kitprog3 manual. It's too bad they did this.
Good luck with your project.
Section 9.1 (List No. 7) requires you to load e KitProg2_Bootloader.elf and e KitProg2_Bootloader.hex file to the bootloader component.
Any idea from where I can get KitProg3_Bootloader.elf. I was able to track hex file for Kitprog3 but not the elf file.
Hello.
WOW!, I can't believe Cypress doesn't include the elf and hex for Kitprog3 when Creator gets installed. And yeah, it's not on my PC either. Historically, those 2 files are always in the same folder.
So, in Kitprog3 user guide, section 2.1, it discusses Kitprog3 using some new "Firmware Loader" tool that can be used to upgrade/downgrade Kitprog3. Links to github are working. Section 6 gives better details about the process.
Maybe you need to downgrade from 3 to 2, if you can find Kitprog2.hex and Kitprog2.elf.
BTW, I found the Firmware Loader user guide:
Infineon-FIRMWARE_LOADER_USER_GUIDE-UserManual-v03_00-EN.pdf
Maybe someone from Infineon will provide an answer. If after a couple of days you don't see any new replies, start a new message asking specifically for Kitprog3.elf and Kitprog3.hex files in order to Build a bootloadable project for Kitprog3 5LP.
Sorry I couldn't help more.
