Hi, community
I would like to know the following about the Capsense 5th generation sense clock settings.
I found that I can enter parameters from the Capsense configurator to set the sense clock.
However, this GUI does not allow the user to select "PRS8" or "PRS12" as in the 3rd and 4th generation Capsense, and in the 5th generation Capsense, they were listed as "PRS".
Q1. In this case, does the "PRS" resolution reflect the CSD Clock Signal setting from the Device Configurator?
Q2. If I set the Clock Signal setting to 16 bit Divider, should I also consider 16 bit resolution for PRS?
Q3. What is the best way to set the PRS resolution at 8 or 12 bits as in Capsense 3rd and 4th generation?
Chihiro Tatebayashi
Hi @NXTY_Tatebayasi -San,
There is an option in PSoC Creator CapSense Configurator as shown below:
For ModusToolbox, we are in internal discussion with the team and we are looking into it. We will get back to you as soon as possible.
Thanks!
Kind regards
Arpit Srivastav
Thanks!
Kind regards
Arpit Srivastav
Hi, @Arpit_S -San
Thank you for your reply.
Is my understanding correct that this is an answer to Q3?
I look forward to your reply.
By the way, am I correct in my observations regarding the sense clock settings in the Modus tool box as shown in Q1 and Q2?
Best Regaerds,
Chihiro Tatebayashi
We won't be able to share the details about this as it is confidential as far as CapSense IP is concerned. We would recommend you to go ahead and use available PRS options from the GUI.
Thanks!
Kind Regards
Arpit Srivastav
