How get PSOC4 UID
Rodrigo_RT
Level 4
Level 4
50 sign-ins 10 likes given 25 replies posted
Hello people.
How is it possible to read the UID of PSOC4?
I need to read the UID of PSOC4 to use in some transmissions.
Best Regards
Rodrigo,
You can find a PSoC4 example project called "UniqueID"   The unique silicon ID is 64 bits.
Here's the simple code:
uint32 uniqueId[2];
int main()
    /* Gets unique id of the device */
    CyGetUniqueId(uniqueId);  /* 64-bits of encode build info */
Len
Len_CONSULTRON
Level 9
Level 9
Rodrigo,
Are you asking about the UUID in a BLE environment or the Unique Silicon ID of the IC itself?
You might want to take a look here: How-to-get-the-PSOC4-BLE-UID-User-Identification
Len
Rodrigo_RT
Level 4
Level 4
Hi!
It would be from the UCID of the MCU's Silicon. like in XMC.
https://www.infineon.com/dgdl/DEV_XMC1000_UCID_v1_0.pdf?fileId=db3a3043419f09c30141a157c58f000c
Rodrigo,
uint32 uniqueId[2];
int main()
Len
Rodrigo_RT
Level 4
Level 4
Thanks a lot for the help.
