ofric_1799416
There used to be a great article that described exactly what needs to be done (http://www.cypress.com/blog/psoc-sensei-blog/using-clocks-psoc-4), but it is no longer accessible. A...
odissey1
Level 9
Level 9
oferr,
There are two ways: (a) to pass clock trough some UDB component (e.g. TFF) or (b) the case described in former PSoC Sensei blog known as Pin clocking (a digital output pin configured for clocking). To see pin configuration you can download PSoC4 demo project from ButtonSW32 demos
ButtonSw32: button switch debouncer component
For pin configuration you don't have to download the component itself, you need only ButtonSw_P4_pin_clock.proj from a Demos folder.
/odissey1
odissey1
Level 9
Level 9
oferr,
/odissey1
