PSoC™ 4 Forum Discussions
NXTY_Tatebayasi
Level 4
Level 4
Distributor - NEXTY (Japan)
5 solutions authored 25 replies posted 100 sign-ins
Hi,community
Is there anything I should keep in mind when designing a write port (SWD) on a board using PSoC4 chips?
When I write a program to the evaluation board using mini Prog4, if the board itself is powered off, I control VTARG from the Psoc programmer to supply power.
Therefore, I recognize that the VTARG pin can be powered.
What is the behavior if the board is already powered on, as in the case of other manufacturers' debuggers?
Is there a so-called "detect function" ?
Please also let me know if there are any manuals that I should refer to when designing the hardware for the SDW terminal.
Chihiro Tatebayashi
AikoO_51
100 sign-ins First question asked 50 solutions authored
You can connect the VTARG pin even if the target board has already been powered by a PC or something.
The VTARG pin can be used for power supply to the target board and managing voltage for Miniprog4 to the same level as the power supply from others
As your attempt, when there is just a target board without a PC connection to supply the power, then it's supplied the power through VTARG from Miniprog4.
Aiko Ohtaka
Infineon Technologies
AikoO_51
Aiko Ohtaka
NXTY_Tatebayasi
Level 4
Level 4
Hi, @AikoO_51  -san
Thanks to your help my problem has been solved!
Chihiro Tatebayashi
