Hi All:
How can I use the WDT0 to generation a interrupt for CY8C4147AZI_S455,could you give me a code example?
PSoC 4 Architecture
You can refer to the attached project. (Change the device in device selector)
Also, refer to http://www.cypress.com/documentation/component-datasheets/psoc-4-low-frequency-clock-cylfclk-version...
Shanmathi
Hi Long,
Please find the code example link http://www.cypress.com/documentation/code-examples/ce95400-watchdog-timer-reset-and-interrupt-psoc-4...
VRS
Hi VRS:
I think the CY8C4147AZI_S455 architecture is different from what you give .For CY8C4147AZI_S455 ,WDT0 is a additional timer.Show as bellow:
If I want to use the watchdog timer for against system crashes and the WDT0 for a periodic interrupt How should I configure the WDT0 ? Both the watchdog timer and the WDT0 used the same interrupt vector?
Shanmathi
