I'm using a CY8CKIT-042 in my design. ALL my I/O is used for other purposes (LCD, SPI, LEDs and the such). How can I detect the voltage of VDD with only internal resources? This is to allow me to set the contract % for the LCD.
PSoC 4 Architecture
Have a look at the "Voltage Detect APIs" in PSoC4 System Reference Guide from Creator help menu.
Bob
PS: There is an "Edit" function to correct typos... 😉
Update: contrast not contract.
Bob
Bob,
That was very helpful. Although it is not an ADC (more like a comparator), I got it to work with some minor caveats.
Code snippets:
uint8 vdd_voltage(void)
result=CY_LVD_THRESHOLD_2_50_V; //set to lowest expected VDD value
for(result=CY_LVD_THRESHOLD_2_50_V; (result<=CY_LVD_THRESHOLD_4_50_V); result++)
CySysLvdEnable(result);
CyDelay(10);
if(CySysLvdGetInterruptSource() == CY_SYS_LVD_INT)
break; // If int set, break out.
CySysLvdClearInterrupt();
return(result);
lcd_contrast[] =
100, // CY_LVD_THRESHOLD_2_50_V
100, // CY_LVD_THRESHOLD_2_60_V
100, // CY_LVD_THRESHOLD_2_70_V
100, // CY_LVD_THRESHOLD_2_80_V
90, // CY_LVD_THRESHOLD_2_90_V
80, // CY_LVD_THRESHOLD_3_00_V
75, // CY_LVD_THRESHOLD_3_20_V
65, // CY_LVD_THRESHOLD_4_50_V
40, // > CY_LVD_THRESHOLD_4_50_V (16u)
void main(void)
uint8 vdd_idx;
all_LEDs(1); /* Add load to VDD */
LCD_Seg_Start();
vdd_idx = vdd_voltage() - CY_LVD_THRESHOLD_2_50_V;
LCD_Seg_SetContrast(lcd_contrast[vdd_idx]); /* Set the contrast for VDD voltage compensation */
all_LEDs(0); /* Remove load from VDD */
CAVEATS!!!
- The LVD thresholds aren't linear. Most are 0.1V to 0.2V steps. The last one jumps from 3.2V to 4.5V.
- VDD needs time to settle. I received lower threshold/voltage values if I quickly cycle the power on and off. That's why my code snippet includes turning on and off the LEDs (higher current draw on VDD) before and after the test.
Hi ,
If you have one pin free, you can use the method specified in this blog. http://www.cypress.com/blog/psoc-hacker-blog/measuring-vdd-battery-volts-psoc4 . Refer PSoC4 implementation section.
VSRS
VSRS,
Thanks for your input. I've created designs with battery voltage monitoring. Sadly with this design, I have no spare inputs. Yuk! Oh well!
Len
