lola_1650581
First like received
Hi all:
        How can I assign the pin to what I want to which has been fixed to a port by a control file?
Vasanth
Hello Long,
Please search for a file of extension .ctl in your workspace explorer.
You have to edit the current file. Please check the control file section in the following document to see the format.
http://www.cypress.com/file/137441/download
VSRS
Yugandhar
1000 replies posted 5 likes given First comment on blog
There will be a force routing for that particular pin. In order to remove that particular pin from force routing, please go to "Design Wide Resources" in the PSoC Creator and select "Directives" and Remove the Directives which are available in the section.
Please let me know if this helps.
PSYU.
Vasanth
Hello Long,
VSRS
