LuNo_297436
First solution authored 10 replies posted 10 questions asked
Hi all,
If i write to TCPWM_WriteCompare() or TCPWM_WritePeriod() everything works fine.
But if I write to TCPWM_WriteCompareBuf() or TCPWM_WritePeriodBuf() nothing happens.
I have read TRM and Data Sheet  but it is not clear to me how the switch input is used?
Attached picture how I connected switch input.
Luis
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Dear Luis-san,
Reading the TCPWM Datasheet, I think that you need to add "switch" to trigger the swap of period and periodBuf,
compare and compareBuf.
You can access the datasheet of a component from the configure dialog .
(Lower left side [Datasheet] button)
or in the sample display of Component Catalog
(Upper left corner Open datasheet link of the symbol window )
27-Jan-2021
Motoo Tanaka
MotooTanaka
Level 9
Level 9
Dear Luis-san,
27-Jan-2021
Motoo Tanaka
Dear Motoo Tanaka
It took me some time to understand and get it working but it works!
The way I made it iwas , connecting a register to the switch terminal in pulse mode, setting swap to 1 writing to buffer (peroid or pwm)then firing the pulse in register.
Some findings :
Connecting the way I did on the attached picture on my first post didn't work because of to much jitter on the falling edge of PWM and some estrange  misbehavior on frequency update.
Thank you so much.
Luis
MotooTanaka
Level 9
Level 9
Dear Luis-san,
Congratulations!
And reading your response, I noticed that I missed your image attachment.
I'm sorry about it.
But this reminded me of an older discussion, which was fun 😉
(It was swapping only compare values, though)
https://community.cypress.com/t5/PSoC-4-MCU/TCPWM-Compare-Registers-Not-Swapping-on-PSoC-4200/m-p/16...
28-Jan-2021
Motoo Tanaka
