PSoC4000 has two GPIO register to set the Port-Configuration (Drive-Mode): GPIO_PRTx_PC and GPIO_PRTx_PC2.
GPIO_PRTx_PC specifies the Drive-Mode of a Pin, and GPIO_PRTx_PC2 is used to explictitly disable the input Buffer for a Pin.
In PSoC4000S TRM it is descibed, that using Drive-Mode 'Analog' in register GPIO_PRTx_PC automatically disables the input buffer.
When I checked the API Code for initializing CapSense Pins, I noticed that Drive-Mode was set to 'Analog' in PC-Register and additionally the input-buffer was disabled in Register PC2-Register.
My Question: Is there a difference in analog characteristics depending on PC2 setting for Drive-Mode-Analog?
Thank you.
PSoC 4 MCU
There's no difference, but if you keep the input buffer enabled with an analog signal on the pin then the current consumption of the device will increase.
That's what i expected, but I want to make certain.
I just wondered about the API code, where the input buffer is disabled twice.
Thank you for your reply !
