ByeByeFlyGuy
I am trying to use a MiniProg3 device with an ARM based Windows 11 host. I cannot get the device drivers to load for the miniprog. It is showing up as an unknown device.
I have tried removing and reinstalling the PSoC Programmer (3.29.1). I also tried manually updating the device driver by pointing the Device Manager at C:\Program Files (x86)\Cypress\Programmer\drivers\mprog3 but it says windows could not find drivers for your device.
Am wondering if I am out of luck on an ARM based PCor if that is a red herring. I have used this miniprog before on other PCs so I believe it is good.
LeoMathews
First question asked 500 replies posted 100 solutions authored
Hi @ByeByeFlyGuy
We regret to inform you that currently, we do not have MiniProg3 drivers for ARM based Windows machines.
Thanks and Regards,
Leo
SuSh_1535366
Level 5
Level 5
Distributor - Macnica (Japan)
10 solutions authored 10 likes given 10 likes received
Cypress Programmer does not support MiniProg3.
https://www.infineon.com/cms/en/design-support/tools/programming-testing/psoc-programming-solutions/
Please try installing PSoC Programmer.
Hi
Thanks for the reply. I meant PSoC programmer (corrected the original post). Sorry for the confusion.
LeoMathews
Hi @ByeByeFlyGuy
Can you please try manually updating the device driver again by pointing Device Manager at C:\Windows\System32\drivers\cypress\miniprog3\PSoCUSB.sys ?
Thanks and Regards,
Leo
ByeByeFlyGuy
Hi @LeoMathews ,
Thanks for the suggestion. I tried this, but there is no `cypress` sub-directory in C:\Windows\System32\drivers on my machine.
Cheers
Nick
LeoMathews
Hi @ByeByeFlyGuy
Can you please refer to this KBA for further troubleshooting and check if this helps?
https://community.infineon.com/t5/Knowledge-Base-Articles/Where-to-Find-the-MiniProg3-Driver-File-KB...
Thanks and Regards,
Leo
ByeByeFlyGuy
Hi @LeoMathews
Yup - I have tried that KBA and Windows complained it could not find drivers there. I am definitely thinking it is something to do with the ARM version of windows not recognizing the drivers.
When I perform exactly the same installation steps on an x84_64 based windows machine, I see all the various drivers appear as installed, but none show up on the Arm based windows machine.
LeoMathews
Hi @ByeByeFlyGuy
The drivers that work on x84_64 based windows machines may not work in ARM version of windows. That is why the ARM version of windows is not recognizing the driver for MiniProg3.
You can try PPCLI commands and check if MiniProg3 is listed.
>Insert MiniProg3 into USB port.
>Open a command prompt window.
>Point to this directory: Program Files\Cypress\PSoC Programmer
>And type ppcli, it should return with the > prompt.
>Now type GetPorts and press Enter.
Please let me know if MiniProg3 is recognized after executing these steps.
Thanks and Regards,
Leo
ByeByeFlyGuy
Hi @LeoMathews
That seemed to get it. ppcli found the MiniProg and it now shows up in PSoC Programmer and PSoC Creator.
Thank you
Nick
ByeByeFlyGuy
I misspoke. I was stupidly following the ppcli instructions on the x86_64 box where the MiniProg is working.
On the ARM based machine, where it shows up as Unknown Device, GetPorts gave an empty reply
LeoMathews
Hi @ByeByeFlyGuy
The MiniProg3 device shows up as an unknown device in ARM based machine because of lack of proper driver files. I have asked our internal team about the availability of driver files for MiniProg3 compatible with ARM based Windows 11. I will update you as soon as I get a response from them.
Thanks and Regards
Leo
Thanks @LeoMathews . I'll look forward to hearing from you
Nick
LeoMathews
Hi @ByeByeFlyGuy
Thanks and Regards,
Leo
LeoMathews
Hi @ByeByeFlyGuy ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Leo
