EsFr_4600111
25 sign-ins 10 replies posted 10 questions asked
Have a cyble-222014 unit, I  want to flash during the production. And i need to write diffrent serial number and settings into each device, can i do this with the psoc programmer? And how.
Br
Esben
DheerajK_81
Hello @EsFr_4600111 ,
We do not recommend using MiniProg or KitProg for production programming. For production-quality programmers, please see our Device Programmer System Partners page for information about third-party programmers.
You can program this data into the SFlash. Please find the reference application for programming the SFlash at this path: "C:\Program Files (x86)\Cypress\Programmer\Examples\Misc\PSoC4-BLE-SFLASH-Update"
Hope this helps 🙂
Dheeraj
DheerajK_81
Hope this helps 🙂
Dheeraj
Hi Dheeraj
Thank you for you answer.
For debugging how do i then manually, modify the user flash area.
Im using the kitpro2  programmer from a pioneer kit.
 Br Esben
Sorry, I didn't get your question. Can you elaborate on your query?
Dheeraj
Just need to know if i can change the flash when from the creator debugger.
No, writing to flash during debugging is not possible. You need to use the flash write routines in the firmware to write to flash.
Dheeraj
