Jun 23, 2019
07:23 PM
Jun 23, 2019
07:23 PM
About CY8CMBR3108S programming
CY8CMBR3108S have some N/A register. When we try to program from host using HEX file.
We can see the value for all of register include N/A register in HEX file.
We will program all of value under the HEX.file.
is it correct?
On the for verification setting data.,
If we read N/A data after above programming, Does it can read same as HEX.data?
Labels
12:41 AM
Jun 24, 2019
12:41 AM
Only valid bit field and registers are applicable in the device.
Please check these bit field/registers in
MBR3 datasheet
MBR3 Registers TRM
And for verification, please check only valid bit fields/registers.
(i.e. you can ignore "N/A".)
