Rach_4524011
HOW TO DEBBUG A SELECT PROGRAM... I AM NOT ABLE TO EXECUTE THE STEPS??
#include <project.h>
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
void config(void);
char ch,ch1;
char str[100],str1[100];
int i = 0,j = 0;
CY_ISR(ISRCmdHandler)           // interrupt handler for CMD
    ch = UART_CMD_UartGetChar();     //connect
    UART_CMD_ClearRxInterruptSource(UART_CMD_GetRxInterruptSourceMasked());
    if(ch != '\n')
        str = ch;
        i++;
    else
        i = 0;
        config();
        memset(str,0,sizeof(str));
//        UART_GSM_UartPutString(str);
//    UART_CMD_UartPutChar(ch);
CY_ISR(ISRgsmHandler)           // interrupt handler for GSM
    ch1 = UART_GSM_UartGetChar();
    UART_GSM_ClearRxInterruptSource(UART_GSM_GetRxInterruptSourceMasked());
    if(ch1 != '\n')
        str1 = ch1;
        j++;
    else
        j = 0;
        UART_CMD_UartPutString(str1);
//        config();
        memset(str1,0,sizeof(str1));
//    UART_GSM_UartPutChar(ch);
void config(void)
    if(strcmp(str,"CONNECT") == 0)
        UART_GSM_UartPutString("AT");
        CyDelay(500);
        UART_GSM_UartPutString("AT+NETCLOSE");
        CyDelay(500);
        UART_GSM_UartPutString("AT+CSOCKSETPN=1");
        CyDelay(500);
        UART_GSM_UartPutString("AT+CIPMODE=0");
        CyDelay(500);
        UART_GSM_UartPutString("AT+NETOPEN");
        CyDelay(500);
        UART_GSM_UartPutString("AT+IPADDR");
        CyDelay(500);
//        UART_GSM_UartPutString("AT+CIPOPEN=0/");
//        UART_GSM_UartPutString("/");
//    else if(strcmp(str1,"OK") == 0){
    UART_CMD_Start();
    UART_GSM_Start();
    ISR_CMD_StartEx(ISRCmdHandler);
    ISR_GSM_StartEx(ISRgsmHandler);
    UART_CMD_UartPutString("UART 1 START\n\r");
    UART_GSM_UartPutString("UART 2 START \n\r");
    CyGlobalIntEnable;
    for(;;)
/* [] END OF FILE */
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Please do not call lengthy function such as config in an ISR.
I would touch your main.c like below to make it easier for me to understand.
And please be careful about overflow of the receive buffer.
In general, you don't have to fill 0 to a str array, but make the index to 0 and
may be write 0 at the first letter.
I wonder if this can be "stepped".
* Copyright YOUR COMPANY, THE YEAR
* All Rights Reserved
* UNPUBLISHED, LICENSED SOFTWARE.
* CONFIDENTIAL AND PROPRIETARY INFORMATION
* WHICH IS THE PROPERTY OF your company.
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#define CMD_BUF_LEN 100
#define GSM_BUF_LEN 100
void config(char *cmd);
volatile char cmd_buf[CMD_BUF_LEN+1] ;
volatile char gsm_buf[GSM_BUF_LEN+1] ;
volatile int cmd_rx_index = 0 ;
volatile int gsm_rx_index = 0 ;
volatile int cmd_line_received = 0 ;
volatile int gsm_line_received = 0 ;
    char ch ;
    if ((UART_CMD_SpiUartGetRxBufferSize()==0)||cmd_line_received) { /* if no char received retrun */
        return ;
    if(ch != '\n')
        cmd_buf[cmd_rx_index] = ch;
        cmd_rx_index++;
        if (cmd_rx_index >= CMD_BUF_LEN) {
            cmd_buf[CMD_BUF_LEN] = 0 ;
            cmd_line_received = -1 ;
            cmd_rx_index = 0 ;
    else
        cmd_line_received = 1 ;
        cmd_buf[cmd_rx_index] = 0 ; /* terminate the string */
        cmd_rx_index = 0;
    char ch1 ;
    if ((UART_GSM_SpiUartGetRxBufferSize()==0)||gsm_line_received) { /* if no char received retrun */
        return ;
    if(ch1 != '\n')
        gsm_buf[gsm_rx_index] = ch1;
        gsm_rx_index++;
        if (gsm_rx_index >= GSM_BUF_LEN) {
            gsm_buf[GSM_BUF_LEN] = 0 ;
            gsm_line_received = -1 ; /* buffer over flow */
            gsm_rx_index = 0 ;
    else
        gsm_buf[gsm_rx_index] = 0 ; /* terminate the string */
        gsm_line_received = 1 ;
        gsm_rx_index = 0;
    if(strcmp(cmd,"CONNECT") == 0)
        CyDelay(500);
        CyDelay(500);
        CyDelay(500);
        CyDelay(500);
        CyDelay(500);
        CyDelay(500);
//    else if(strcmp(cmd,"OK") == 0){
    UART_CMD_Start();
    UART_GSM_Start();
    CyGlobalIntEnable;
    for(;;)
        if (cmd_line_received) {
            config((char *)cmd_buf);
            cmd_rx_index = 0 ;
            // memset(str,0,sizeof(str)); // this is not necessary
        if (gsm_line_received) {
            UART_CMD_UartPutString((char *)gsm_buf);
            gsm_rx_index = 0 ;
            // memset(str1,0,sizeof(str1)); // this is not necessary
moto
Rach_4524011
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
void config(void);
char ch,ch1;
int i = 0,j = 0;
    if(ch != '\n')
        str = ch;
        i++;
    else
        i = 0;
        config();
    if(ch1 != '\n')
        str1 = ch1;
        j++;
    else
        j = 0;
//        config();
void config(void)
        CyDelay(500);
        CyDelay(500);
        CyDelay(500);
        CyDelay(500);
        CyDelay(500);
        CyDelay(500);
    UART_CMD_Start();
    UART_GSM_Start();
    CyGlobalIntEnable;
    for(;;)
MotooTanaka
Level 9
Level 9
#include <string.h>
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
    char ch ;
        return ;
    if(ch != '\n')
        cmd_rx_index++;
            cmd_rx_index = 0 ;
    else
        cmd_rx_index = 0;
    char ch1 ;
        return ;
    if(ch1 != '\n')
        gsm_rx_index++;
            gsm_rx_index = 0 ;
    else
        gsm_rx_index = 0;
        CyDelay(500);
        CyDelay(500);
        CyDelay(500);
        CyDelay(500);
        CyDelay(500);
        CyDelay(500);
    UART_CMD_Start();
    UART_GSM_Start();
    CyGlobalIntEnable;
    for(;;)
            cmd_rx_index = 0 ;
            gsm_rx_index = 0 ;
moto
