In software how to enable guard sensor for CY8C4025AZI-S413.....I found shield pin in cydwr, but guard pin is not found. then how to assign a pin for guard sensor & how to access guard sensor..
Hi BhSa_4078721
The guard sensor is not directly implemented in the latest CapSense component. Guard sensor should be treated as a normal CapSense sensor. In application code, you can implement the guard sensor such that when it is active (due to presence of stream of water), all other sensors are disabled.
You can find a sample project that demonstrates the same in this thread: Regarding PSoC4S sample project using guard sensor.
Thanks and regards,
Hari
Hi BhSa_4078721
Thanks and regards,
Hari
