I have been trying for a while to find the GraphicLCDIntf component download specifically for the CY8CKit-041/2 boards but can only find the component available on the CY8CKit-059. Does this imply that the component cannot be used on PSoC4 devices? I note that in PSoc Creator 3.2 that the component will appear in the Catalog for the 059 but not the 042. If there is no underlying reason why the component will NOT work on the 042, how do I enable the component in the Catalog?
Thanks for your assistance.
Welcome in the forum, Denny.
Components have a property that describes on which underlying hardware they will run. There is a large difference between PSoC5 and 4 (DMA, number of UDBs) that could affect a component. So it will be of no use just to "enable" a component for another family of devices.
A way out:
The graphic interface consists of two different parts:
The routines performing the graphic functions as floodfill, clear screen or linedraw...
The interface that actually "talks" to the graphic chip.
The former is quite universal and there are libraries out in the web, ask Mrs. Google. The latter is something that you have to provide. A nice job, but usually doable.
Happy coding
Bob
There are several projects here on GLCD -
PSOC 4 element14.com
Regards, Dana.
The Great !!!
